Microphonic components problem....
Started by danielzink, January 04, 2010, 03:01:41 PM
danielzink
Okay,
I've got this pedal out there - mind you - I've built a bunch of the same pedal with no issues.
This one has microphonic issues ie: the switch pops (more like a "bell ring") when engaged. And when "on" if you slightly move the switch you can hear the "spring" inside the switch moving.
I've already replaced the switch once - now it's coming back for it's third switch. Should I be looking elsewhere ?
Again - this same build for several other people has had no issues - and it wasn't making noise when it came back for the first replacement switch.
Thanks, Dan
Processaurus
tap around on components with a plastic pen (anything non conductive).  ceramic caps especially can be microphonic.
danielzink
Quote from: Processaurus on January 04, 2010, 10:05:09 PM
Yeah - I thought of that......any ? ceramic caps ?. The only ceramic in this build is a 100pF multiceramic (teeny tiny little thing)...
Thanks !
Dan
kurtlives
+1 for the tapping. I do that a lot with chopsticks when I am troubleshooting issues like this with amps.
I might also try a new brand of switch.
My DIY site:
www.pdfelectronics.com
