wah transistor problem (determining Collector, Base, Emitter)
Started by philbinator1, January 11, 2010, 08:19:05 AM
philbinator1
Hi Guys
I'm having a problem with a mates wah i'm trying to fix; it goes fine when off (clean sound) but i get nothing when
it's engaged.  without thinking i took the old transistors (5117's) out and can't remember the proper orientation for
the new ones, also i think the new ones (2N4401's) have a different C-B-E configuration anyway..I'm pretty confused.
Is there a way to determine which leg is which on the tranny (cue lude jokes) without having to go on the net and
try to find the datasheet for the 2N4401?
cheers
Phil
"Hows are we's?  We's in the f*cking middle of a dinners meal!  Dats hows we am!" - Skwisgaar Skwigelf
~arph
philbinator1
 :) Enlightening  :) .  As it turns out, i can't find the datasheet for the 5117 transistor.  any ideas?
anchovie
5117 transistor pinout
Looking at the flat face with legs down:
flat face
 ECB
Looking from bottom with flat "downwards"
BCE
A second check,
IIRC if you use your multimeter diode range the CB junction has a slightly lower voltage than the EB junction.
Not sure what board you have but the Emitter will go to the 470ohm resistor on one transistor and the 10k on the other - on one board that meant the emitters were towards the edges of the PCB and the collectors towards the inner (the transistors faced in opposite directions).
philbinator1
Thanks guys, what a big help that is!  Really appreciate that, i'll get back to you with what results i have, as a final
enthralling climax to my wah ordeal   ;D
