Traynor Foot Switch Help...
Started by MarkR2955, February 04, 2010, 02:53:17 PM
MarkR2955
I have a friend needing work on a Traynor 4-channel footswitch for the YCS-100. The switches seem to be shot. Is there an easy way to tell if the switches (which appear to be DPDT) are momentary or latch?
There are 10 types of people in the world - those who understand binary, and those who don't.
ppatchmods
picture could help. but the easiest way to tell is to push them and see if they pop. what type of connection is used to connect to the amp?
When your life is over, will any of this STUFF really matter?
azrael
Yeah, what kind of cable are you using? I remember my YCV40 using a stereo cable, but it only had 2 switches.
MarkR2955
They sort of pop, but then again so to the momentary switches I have...Oddly it uses a midi cable...
ppatchmods
if it is midi they are more than likely momentary switches. they probably just send a signal to the amp and make the switch digitally.
MarkR2955
that's what I was thinking - thanks, I'll try those.
