Etching Station
Started by Andy, September 28, 2003, 09:26:43 PM
Andy
Does anyone know the address of that picture where the guy made a plexiglass container and had a heater in it with an airstone?  I can't find it in my favorites.
Andy
Rick
Don't have the address anymore but I tried this idea with an ultra cheap aquarium once. The aquarium will hold up to the etchants but the airstone does not (turns into a pile of sand in short order). Better to replace the airstone with a small plastic tube with tiny holes poked into it, maybe several tubes, then afix it/them to the bottom of the tank with the air hose attached.
Even a heavy-weight drinking straw (from a slushy) works great - just seal up the end with some hot melt glue. All the stuff req'd for this is in the Wall Mart fish section - aquarium heaters, air pumps etc.
It does work quite well for a while but the fish tank heaters die like goldfish. I just use an old microwave or even a light bulb to warm the etchant and float my circuit board on top. Works just as well for small boards.
Andy
I devised one tonight using an old vase and a heater and an air pump.  Problem is, to get the etchant above the heaters water level I will have to use a WHOLE bottle at once.  How long would this bottle (32 oz) last if I used the entire thing for every etch?  I'm wasting it aren't I?  I wanted to see what that guy had again to give me an idea.  I could buy some plastic and build a section dedicated to the heater and a section dedicated to the boards.  That way, minimal amount of etchant is used.  I plan on doing sorta what you said by attaching a hose across the bottom.  I remember someone else saying that about the stones.  When I get one designed, I will try to post plans here for everyone.
Andy
Jered
You can use, and re-use ferric chloride as long as it works. You'll know when its time to replace it.
  Jered
Thomas P.
I'm not sure, but maybe I'm the guy you searching for!
Bad news first: I don't know the link anymore :(
I built my machine of polystyrol (something like plexiglass).
For echtant I use Natriumpersulfat and I eched 7 boards with it over 3 months. I think it'll last for seven more boards :wink: .
If you want to save etchtant build one and make it very thin - then you'll have min. amount of etchtant to use.
Regards,
tomboy
god said...
∇ ⋅ D = ρ
∇ x E = - ∂B/∂t
∇ ⋅ B = 0
∇ x H = ∂D/∂t + j
...and then there was light
