Line 6 volume issue
Started by adubadee, February 17, 2010, 03:12:39 AM
adubadee
Hello all!
I'm hoping to fix the loss of volume on my Line 6 DL4, & FM4. I have searched the internet, and have found a bunch of guys that can fix the problem, but no DIY info. Any help would be appreciated.
Thanks for your time.
DD
Processaurus
http://www.aronnelson.com/gallery/main.php/v/MrHuge/Line+6/
There's some other good info there too, on those pedals.
If you haven't de-soldered surfacemount resistors before, you can do it with a regular soldering iron, just go back and forth on each side of it, quickly, until one side stays melted when you're melting the other, and it will lift.  You can kludge a regular 1/4 watt resistor onto the pads.
