Capacitor Polarity on Layout?
Started by keto, February 18, 2010, 11:34:09 AM
keto
I'm very much wanting to build this.  I can read a schematic, as in, I can see the value of parts and know which are res/cap, where is ground.....but I just cannot get my head around relating a schematic to a layout.....and the layout doesn't give the polarity of the electrolytics.
http://www.aronnelson.com/gallery/main.php/v/Xaviers-shrine-of-noise/Layouts/Colorsound_overdriver.gif.html
C12, C5, C10 I suspect are easy, as they are all associated directly with the ground wire - so, the bottom of the cap is neg.
C2 - up or down?  my guess is up, due to the current flowing then to R1 and ground
C4 - up or down?  my guess is up, again just following the connections until I find ground
C9 - up or down?  Uhhh, this one really has me baffled.
Thanks in advance :)
Steve Mavronis
You can place a square pad to denote the positive lead for polarized capacitors and diodes, just as you may use them to denote pin 1 on IC chips and pot pads.
Guitar > Neo-Classic 741 Overdrive > Boss NS2 Noise Suppressor > DOD BiFET Boost 410 > VHT Special 6 Ultra Combo Amp Input > Amp Send > MXR Carbon Copy Analog Delay > Boss RC3 Loop Station > Amp Return
StereoKills
Actually, the layout does denote polarity on the electrolytic caps. If you look really carefully, you will see one side has a slightly dark shading to it, which marks the negative side. Plus, as Steve mentioned, the square pads show the positive side.
"Sometimes it takes a thousand notes to make one sound"
