A nice shiny enclosure. But how?
Started by asfastasdark, October 17, 2008, 08:35:27 PM
tremendous
Just a quick question - has anyone had any experience of using a sander to do this? I'm starting to get sore arms from too much sanding and would love to use a belt sander/mouse sander/something/
Anyone got any thoughts on this?
thanks,
d.
Toney
Heres one I have been wondering about.....
Is there any way of adding water-slide or other decals and then clear coating over a polished finish?
I ask because I have learned that to paint properly you must use etch primer, not regular primer to achieve a decent effect.
tiges_ tendres
Quote from: tremendous on April 27, 2009, 06:42:52 PM
thanks,
d.
Resurrecting an old thread, but, I have a similar question to the above.
I understand that when sanding aluminum, its preferable to wet sand.  This rules out most electric sanders, but what about sanders that run off of an air compressor?
I know they work wet and dry, but does anyone have any experience using something like this on enclosures?
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=96445
Try a little tenderness.
objectx
I've had some good results polishing aluminium using the progressive sanding technique and then doing a final buff with some ultra fine steel wool (the type used for french polishing). It tarnishes pretty soon though anyway.
walker
BTW, if you need those crazy grits like 400, 800, 2000, etc.  Autozone, Pepboys, and the like are good sources.
tiges_ tendres
Quote from: objectx on March 05, 2010, 05:19:32 AM
I've got the tarnishing part covered, I just want to make sure that the tool is suitable for the job at hand.  I thought maybe someone here would have some first hand experience using a tool like this.
Taylor
They're only available in 125B size, but PPP and Small Bear carry nicely polished enclosures for about $4 more than the plain box. Beats a busted elbow in my book.  :)
darron
If you aren't polishing it and are just making it shiny with fine steel wool then it will tarnish with your finger acids etc. Seal it with some WD-40. Mmm. Smells good.
