Interpretation Q about the Guytone FL3 schem.
Started by solderman, February 12, 2010, 09:33:33 AM
Ummagumma
ok, great, keep up the good work then. ;)
we will patiently wait for your layout.
bye
solderman
Hi
The Eagel has landed, Huston we have Flanging
And it sounds just grate. No LFO ticking or any thing. I tested VR3 and R5 with a variable pot to find the spot where feedback is optimal. In my case 106K
The only thing I'm can think of is to increase the MAX speed, I will try with a 680uF but I did not have one in stock so I have to buy one and test. I have also updated the documents in the links to the PDF documents above. The silk and BOM is now inside the layout but I could not delete those links above. Use the PCB and the layout.
Here is the look
And here is the sound
Depth 100% Rate 50%
http://solderman.fatabur.se/FL3/fl3_D100_R50.mp3
Depth 100% Rate 100%
http://solderman.fatabur.se/FL3/fl3_D100_R100.mp3
Max everything regen and a bit feedback
http://solderman.fatabur.se/FL3/fl3_crasy.mp3
I remade my layout from the ground and managed to get everything in to one board. I also did some mods suggested above.
Removed the FET bypass and its components added a true bypass
R05=4K7
R5+VR3~100K (keeps some range for feedback increase to 150K if not wanted)
Decreased C19 to 10uF
Omitted C01
Changed the Resonance switch for a 100KA pot
Omitted R29
Possible mod is to use a 680uF for C02 to get a faster Max rate
The only bad sounding stomp box is an unbuilt stomp box. ;-)
//Take Care and build with passion
www.soldersound.com
xSolderman@soldersound.com (exlude x to mail)
Ummagumma
wow, great flanging there solderman!!!  :o
also you did amazing work and fit all of that in one 1590A?! (I still can't understand how you do it?)
this project became first on my to-do list! :)
doc_drop
Sounds good Solderman!
I got my perf layout working yesterday as well. I will post my layout and schematic once I have a chance to draw them up in DIYLC. (I drew it by hand, and it is too messy to post...) There aren't many DIY able flangers out there, so I want to make sure we have this one out there for the people!
solderman
Hi Doc
That's a good thought. I specially like the FL3 since it's based on the MN3207 and not the more pricy MN3007. A 3007 is € 8,57 ($12) and a MN3207 €2,68 ($3,85) at www.banzaimusic.com where I buy them. You might argue that it's cheaper in the US but don't forget the customs to Europe.
I have sort of hooked on flangers at the moment. I happen to have two MN3007 in stock so I thought I would give the John Hollis Ultra flanger a chance. I made a layout and it fits in a 1590A as well. It's built around the MN3007 CD40406. I'll publish the layout etc as soon as it's verified.
www.soldersound.com
doc_drop
The reason I first looked at this circuit was because I bought (5) MN3207/3102 chips for US $16.88. Super cheap!!!! Like me.
He still has a bunch, so if people want to build this, they should jump.
http://cgi.ebay.com/5-x-MN3207-5x-MN3102-chorus-delay-flanger-BBD-chips-IC_W0QQitemZ120499809309QQcmdZViewItemQQptZGuitar_Accessories?hash=item1c0e592c1d
solderman
Hi
That is cheap. I might get me some and build this one as well
http://www.morleypedals.com/sfbes.pdf
And maby a delay when i'm at it :-)
www.soldersound.com
