Anyone have a Dremel and a pair of vernier/digital/dial calipers?
Started by composition4, March 18, 2010, 07:58:02 AM
composition4
I'm building a PCB drill as mentioned in another thread.
If you have a Dremel, a pair of vernier/digital/dial calipers and a spare 30 seconds, can I ask a favour?
Can you please measure the OUTER diameter of the 3.2mm collet?  The little attachment that goes into the end of the dremel, and you put the drill bit in it...  I'm after the measurement of the bottom part as highlighted below
Thanks heaps
Jonathan
Mr. G.
If nobody else does it first, I can try to remember to take my calipers home with me after work and measure mine tonight.
composition4
jrem
My shanks on collets measure 0.170".  I would think the ID of the chuck is 0.187" or 3/16" nominal.
composition4
Mr. G.
Quote from: jrem on March 18, 2010, 01:08:08 PM
yep, I also got 0.170"
