Hot Silicon Fuzz Problem
Started by Schappy, March 30, 2010, 12:38:41 PM
Schappy
Im having problems with the wiring of the gain pot on my Hot Silicon Fuzz.
The wires are very sensitive and any slight movement shorts the signal.
Any suggestions?
jacobyjd
Check for solder bridges?
If it's just the pot wiring that's the issue, I'd try hooking up a different pot and redoing the wires. If the pot is bad, you'll know, and if it's just the wiring, you've already re-done it :)
