How to pick a transformer for a ring modulator?
Started by soggybag, April 02, 2010, 12:40:48 AM
soggybag
I want experiment with a transformer based ring mod. How do you pick a transformer? I figure I will run it off 9v.
Looks like the Ring Stinger uses a 20K:1K. Does anyone know what's used in the Ringtone?
DougH
http://www.asciipr0n.com/4096/ringmod/index.html
This shows the "simple ring modulator" circuit and quotes a Mouser part number for the transformer. Maybe try looking up the specs on that transformer?
cloudscapes
I've used both the 42TL016 and 42TL218 with success
{DIY blog}
{www.dronecloud.org}
soggybag
Thanks for the reply. Looks like these are all the usual suspects. I think I even have a few of these in the parts bin.
What's the difference between using a 10K:10K vs a 20K:1K? The Ring Stinger seems to break the rule of using a transformer with equal coils. Does this help get over the diode drop. Or does it make a difference with your input buffer?
