How do you remote relay switch but for 2 channels of a pedal?
Started by KH602, April 03, 2010, 09:30:45 AM
KH602
hi there, am just wanting to know how do you go about using a remote relay but for 2 channels
example - switch between an overdrive or clean signal of a pedal via remote pedal
i know how to make a remote relay to turn the effect on and then off (true bypassed) but not sure about the 2 channels..
it would be good to have true bypass from the 2 seperate channels also if that makes sense.
it kind of reminds me of my marshall mg 250dfx combo amp overdrive & clean channel then dfx on and off.
anyone help
cheers
