Barber Silver LTD PCB layout
Started by lazerphea, April 11, 2010, 05:36:54 AM
lazerphea
Hello everyone,
I decided to try the DIY Press'n'Peel method to print PCBs, so I created an (ugly) layout for the Barber Silver LTD; it's my first experiment with Eagle CAD, and I'd be very grateful to everyone willing to check it.
The question is: since Mr. Barber kindly donated us the schematic, not the PCB layout, can I post it here or there are any problems regarding copyright or similar? :)
Talon5051
In the thread http://www.diystompboxes.com/smfforum/index.php?topic=72917.20 that David Barber donated the schematic he was asked if it is OK to post a layout and he said that it is fine.
QuoteSure make a layout and post it if you like, I won't mind as long as it does not become the next $400 swirly mojo pedal.
lazerphea
#2
Quote from: Talon5051 on April 11, 2010, 10:06:15 AM
Thank you Talon5051!
So here's my layout:
I used the default settings, exception made for the traces I made bigger, because I don't know if P'n'P method can render smaller ones; as you can see I have substantially followed the schematic's layout (http://www.barberelectronics.com/Barber_Electronics_DIY.html).
KazooMan
Madbean posted a PCB layout after Steve Barber said it was OK to do so.  When I looked back at the thread it appears that the link to the layout has gone bad.  I have one of the several revisions that were posted.  I do not know if this is the verified version or not, but you can compare it to yours.
I am also assuming that it is OK to post this.  If Bean wants it down, just let me know.
lazerphea
