simple od/boost build with mid-hump (a la TS)
Started by euronymous0001, May 07, 2010, 11:37:12 AM
euronymous0001
hi!
i've searched but with no luck, so maybe could point me to the right direction.
i want to build a simple od/boost that is comparable or similar to a TS,
it will be used as a booster/tone coloration of an already distorted amp
or dist pedal, what i need is the mid hump of the TS (also increase in treble,
though im not sure if the TS has this).  thanks for the help guys.  :icon_biggrin:
MikeH
A TS with the gain rolled-down does this pretty well too
jkokura
Quote from: euronymous0001 on May 07, 2010, 11:37:12 AMhi!
If you want the sound of a TS, then why not build a TS? I love them, and they're easy to build and get parts for... And like someone said, roll of the Gain and it works just like you want it to. Then you have a multi-trick pedal instead of it just doing one thing.
Jacob
