A Hand with Express PCB
Started by Scruffie, June 01, 2010, 12:22:45 PM
Scruffie
I wanna take a good stab at Express PCB to start doing my own layouts as I like to have a few things available such as onboard pots when i'm building PCBs up and layouts that include them are not always available and I was wondering if someone could possibly send me an .PCB file with onboard pots so I could get to grips with the program and make sure I get the sizes for parts right etc. it'd certainly be a handy learning tool for me.
Cheers in Advance.
(P.S. Unless someone already has a EHX Bad Stone & Tri-Vibe layout with onboard pots already made  ;) )
.Mike
I made this for the Futurlec 16mm Alphas. Extract it to My Documents\ExpressPCB\PCBComponents_Custom and then look for it in ExpressPCB's custom components section.
I've used it for several builds, but I'm not sure if it's what you're looking for. :)
Mike
If you're not doing it for yourself, it's not DIY. ;)
My effects site: Just one more build... | My website: America's Debate.
Scruffie
Assuming the spacing is the same for the Right Angled/ Board Mounted Pots yeah that's pretty handy thanks, should make layouts go smoother  :)
It's sort of what I was looking for, I was looking for a complete layout someone wouldn't mind passing on just so I know what a good working layout should look like but that will help when the time comes to make the layouts so thanks for that again  :)
Steve Mavronis
#3
Hi, I use ExpressPCB/SCH and (besides to the pots you want) I have made some my own custom components and symbols too that I can share for anyone to use. I did small drill holes and larger pads on purpose to aid as a drill centerpunch and for easier soldering. I tend to use thicker 50mil traces too for simplier PCB circuits, but you can ungroup the component to redo the pads, then group and resave it again to your liking:
SNM-PCBComponents_Custom.zip
http://home.comcast.net/~snmavronis/SNM-PCBComponents_Custom.zip
    Cap - Ceramic (115mil pads 20mil holes).p
    Cap - Electrolytic (115mil pads 20mil holes).p
    Cap - film (115mil pads 20mil holes).p
    Cap - Mylar (115mil pads 20mil holes).p
    Cap - Radial electrolytic (115mil pads 20mil holes).p
    Diode - 1N4148 (115mil pads 20mil holes).p
    IC Dip -  8 pin (80mil pads 20mil holes).p
    IC Dip -  14 pin (80mil pads 20mil holes).p
    IC Dip -  16 pin (80mil pads 20mil holes).p
    Resistor - 0.25 watt  (115mil pads 20mil holes).p
SNM-SchComponents_Custom.zip
http://home.comcast.net/~snmavronis/SNM-SchComponents_Custom.zip
    3PDT Switch Lugs.s
    DC Jack.s
    DC Jack Lugs.s
    IC - Op Amp LM741CN.s
    Mono Jack.s
    Path Jumper.s
    PCB Input.s
    Stereo Jack.s
Guitar > Neo-Classic 741 Overdrive > Boss NS2 Noise Suppressor > DOD BiFET Boost 410 > VHT Special 6 Ultra Combo Amp Input > Amp Send > MXR Carbon Copy Analog Delay > Boss RC3 Loop Station > Amp Return
.Mike
#4
Check out my topic here. I posted a zip file that has my ExpressPCB files, pictures of the etched-and-unbuilt board, and pictures of the finished board. :)
Edit: There's also another one of my projects using the same pots over at the other forum, page 5 of the "Colorsound - Power Boost / Overdriver" topic.
Mike
Steve Mavronis
Quote from: .Mike on June 01, 2010, 04:18:58 PM
Excellent Mike. A bit off topic but how did you get those little inline thumbnail images that link to the full size ones in your post. Also I like you included the waveforms too! I need to document like that. :)
.Mike
Upload via ImageShack, and then use the code listed as "Forums" under "Thumbnail Size". Piece of cake.
Scruffie
Cheers Guys, that lot should get me started, i'll give these a whirl and see how I get on, if anyone has any other tips though they'll be appreciated too  :)
