Couple of questions.....
Started by dmc777, May 23, 2010, 07:26:25 AM
dmc777
First, does anyone know of a simple blend control schematic AND a phase inverter schematic that I could use? How would I wire them in a pedal?
Also, does anyone know where to find the schematic for a deluxe electric mistress? I'm planning on wiring it for TB and would like to figure out how to fix the volume drop and possible add a blend control.
The phase inverter is going to go in a blender pedal I making right now that I'm going to use for parallel. Any help would be highly appreciated. I'm still new but these things have been bugging the hell out of me. I'm sure the DEM volume drop fix is a simple resistor change. Thanks guys.
GibsonGM
Search the forum for "splitter blend".  There are several splitters out there, which give you phase options, too.
This one is popular and does both:
http://www.runoffgroove.com/splitter-blend.html
For the Dlxe Electric Mistress, try searching the net and here - I know they have the regular (not Deluxe) one:
http://www.schematicheaven.com/effects.htm
Mark F
 General Guitar Gadgets has a schemo and BOM etc. Here is the Schemo link.  http://www.generalguitargadgets.com/diagrams/dmistsc.gif
dmc777
Thanks for the links and replies guys. I'm pretty sure the newer version DEM doesn't use the SAD chip but I do see what appears to be a gain adjustment trimpot. Maybe a slight adjustment of that would help with the volume drop. Think it's safe?
