BSIAB2 PCB Layout versions Help!
Started by robotubo, May 28, 2010, 09:35:39 AM
robotubo
I cant seem to find the third version layout scheme of the BSIAB2. One version is at GGG, the other is at gaussmarkov.net.  The third layout is hard to find and I want that layout. Does anybody have a parts and layout of this???  Thanks you
Bucksears
I've always stuck with the GGG version - he had the original BSIAB and then the II later. Current BSIAB II there is pretty compact and should be able to  fit in the 125-B case, I think.
arma61
#2
I have my own one, 7cm x 3cm (2.75 in x 1.175in) including pads for countor pot.
I can upload in the gallery the ExpressPCB+SCH files tonight (here is 20 to 5pm) so you can play with it.
Ciao
"it's a matter of objectives. If you don't know where you want to go, any direction is about as good as any other." R.G. Keen
