wah output buffer
Started by olslick, June 11, 2010, 10:09:06 PM
olslick
i have a dunlop wah that has been true bypassed, and had the output buffer removed. i'm building a fuzz central output buffer and need some help figuring out how to wire it up to the wah itself. here's the layout... http://fuzzcentral.ssguitar.com/mccoy/bufferlayout.gif
mth5044
You would place it between the wah circuit and the switch. As it says on the picture, 1 and 5 need to be grounded. Take the output wire from the wah circuit that is going to the switch then to the outjack, and take that wire and unsolder it from the switch. Have that wire (the output of the circuit wire) soldered to 2. Then take the output of the buffer, 4, and connect it to where the output of the wah circuit was on the switch. 3 needs to be connected to +9V, which can be jumped off the wah circuit, but it would probably be easier to just run a wire straight from the power jack to that solder pad. You would need a multimeter to tell which is +9v when voltage is applied, or you might be able to figure it out by looking at it.
