Changing values in a Rangemaster circuit
Started by mordechai, June 09, 2010, 09:44:52 PM
mordechai
What happens to the signal in a Rangemaster circuit when:
1. The value of the 3.9K resistor on the emitter of Q1 is raised (to, say, 4.7)?
2. The 10K Audio taper boost pot is changed to a pot of higher value (e.g., a 20K) or lower value (a 5K)?
phector2004
Brymus
Look at GEOFEX and search for  rangemaster
http://www.geofex.com/
RG has a nice pdf there that will explain how to bias it and pick caps.
