a little different
Started by 23, June 21, 2010, 11:30:43 AM
Im looking  for a DIY impedence device called Mike Mojo, its for harp players to plug straight into an guitar amp with "i assume" little to no worries... Im not a harp player yet but have been experimenting with the instrument for a while now, gonna buy my first mic soon, any suggestions on that? Looking at an astatic.
thanks sands
put it together, now take it apart
CynicalMan
I assume you mean this: http://web.archive.org/web/20050925132426/http://www.ironmancurtis.com/MMojo.txt
A FET buffer would probably be easier, higher fidelity, and wouldn't need a Vr circuit or two 9V batteries. Also, the article says an infinite input impedance, but it's really 300k and up, depending on the 741.
23
point me in the fet buffer direction please........ i know there used in inputs and outputs but Ive never really been able to completely isolate one...by the way thanks for the reply.
23
Never mind, but what would be best for harp, everything Im finding is for guitar, or should I just use one for peizo?
CynicalMan
Check out the fourth picture down here: www.muzique.com/lab/buffers.htm
I would probably increase the 1M resistors to 2M2. The second picture would also work, although with less headroom.
23
thanks alot, I found that page but wasnt quite sure.......again thanks
sands
