How to make BSIAB II by Gaussmarkov brighter and with more headroom?
Started by robotubo, June 15, 2010, 05:00:07 PM
paulyy
If you remove both c12 and c13. This will open up the circit and make it brighter. I didn't care for it but mess around with it. You might like it. I also removed c7, c9 and c10. I did not replace them with anything. You can try this and see if you like this at all as well. As far as less gain, try messing with R11. I notice a difference in gain when I was messing with it. Hope this helps. If not, you can always search for BSIAB2 in the forum. Theres ton of info for this pedal. Good luck :icon_mrgreen:
alfafalfa
