Pot resistance?
Started by jable1066, July 11, 2010, 05:29:15 PM
jable1066
I have hit a block with a current build which I will go into detail later if neccessary... I was debugging however, and tested the resistance of the 3 pots connected - all of these are linear 100k pots - and found that 2 of them show resistance of 100k and one at 50k. Is this normal? I tested the resistance between lug 1 and 3. Could this be causing the pedal to not effect properly - all I get is a clean signal...
Govmnt_Lacky
Disconnect the pot entirely. Rotate the pot ENTIRELY clockwise. Now read between the center terminal and the left......then the right terminal.
What do you get?
JKowalski
You can't usually measure resistance in-circuit (with the component hooked up to the circuit) because any parallel resistance will throw values way off.
