Trying to switch between output caps, got really loud!
Started by spargo, July 10, 2010, 05:40:14 PM
spargo
I'm breadboarding an overdrive pedal that I want to use a SPDT switch to go between different EQ (more/less highs).  The default is signal > capacitor > grounded resistor > output.
I installed the switch so it went like this: signal > SPDT input, which switched between: C1 > R1 > ground and C2 > R2 > ground.  Sounded fine.  Then, messing with the resistor values it seemed like that influenced it more than the capacitors, so I had a genius idea to only switch between the grounded resistors, not the cap.  So I did this...
Signal > capacitor > SPDT input, which switched between R1 > ground and R2 > ground.  The result?  Both switch settings seem to sound the same even with different resistor values, but it got REALLY loud all of the sudden.  Why is this?  As a side note, I kind of like it and would be nice to keep the loudness (which doesn't seem to affect tone), while keeping the correct switching between highs/lows for the output.
blooze_man
Is the new resistor a higher value? I'm still kindof a noob, but my understanding is if the resistance to ground is raised, then more signal is going to the output
Big Muff, Trotsky Drive, Little Angel, Valvecaster, Whisker Biscuit, Smash Drive, Green Ringer, Fuzz Face, Rangemaster, LPB1, Bazz Fuss/Buzz Box, Radioshack Fuzz, Blue Box, Fuzzrite, Tonepad Wah, EH Pulsar, NPN Tonebender, Torn's Peaker...
lerxst88
like you were switching resistors for a while and didnt hear any difference and then suddenly you got tons more output? I would guess you disconnected the resistors path to ground so you get 100% signal out of the pedal.
You could put a pot at that intersection and have an output volume control!
What pedal is this based off of? there might be a better place to switch cap values for a "high/low" switch
Quote from: spargo on July 10, 2010, 05:40:14 PM
lerxxt88 is on the right track. By considering only R1/C1 and R2/C2, you are ignoring the effect having both versus only one of them has on the stage driving them. The output impedance of the driving stage matters a lot in many circuits.
How much and what? Have to see the schemo to guess/calculate about that.
spargo
This is for a bluesbreaker circuit.  I'm trying to switch between the output resistor and cap.  Like I mentioned, I had it working to my liking but when I tried to only switch resistors and not caps it got a lot louder.  I was wondering how I could have it that loud but still keep the correct switching I previously had. :)
