GGG AB/Y How to wire as a splitter without switches
Started by sjaltenb, August 13, 2010, 08:52:38 AM
sjaltenb
Sorry for all the questions in the past day.
I need to wire this:
http://www.generalguitargadgets.com/pdf/ggg_amp_aby.pdf
without the switches and LEDs.
Right now I just have the orange wire (the "ring") wired to the ground since an input jack won't be used. the tip is obviously the input from my other effects.
What do I need to do with the other wires?
sjaltenb
NVM. got it.
FYI, you just have to ground the ring and leave everything else alone.
