Electra help
Started by K3vin, August 11, 2010, 09:22:05 AM
K3vin
So i built an electra. With no switch or anything, just the jacks straight into the pedal and all i get is a very loud hum and no signal. i think i might have wired the jacks wrong. Could someone give me a diagram of an electra on stripboard( i used dragonflys layout) but without a switch? also is his layout verified? I tried switching the transistor around.
ckyvick
got pics? how are you grounding it? these instructions can be used as a reference in wiring without a box/switch
http://www.buildyourownclone.com/confidence.html
K3vin
i'll get pics up later today. but do i just need to connect the sleeves to ground? or can i just solder them together?
  The circuit, input and output get common to ground, it is the reference, like a base of a jack, it stays put [hopefully/usually] and the input voltage, referenced from ground...you need two wires for a circuit, one side of the signal stays at/is connected to ground, 0.0v.
  Since this is NPN neg. gnd., - of the power supply also connects to ground.
  Both sleeves [connect the input and output ground], anything else with a ground symbol, should be common/ground/0.0vdc.
K3vin
i think that one of the jacks are broken bcause i tried just soldering the jacks together and there is the same loud hum and no sound. i was using stereo jacks should i use mono?
anchovie
Post a picture of the jacks soldered together.
K3vin
