camel toe clone
Started by MmmPedals, August 13, 2010, 03:18:02 PM
MmmPedals
I want to build a camel toe for someone. Its just a TS and a red lama in one box. simple enough. But i noticed a series parallel switch on it.
Anybody know which comes first in "series" mode? I would have guessed the TS id first but it looks like the red lama is first.
Once I'd plucked up the courage to Google Camel Toe I found this
http://reviews.harmony-central.com/reviews/Effects/product/Way+Huge/Camel+Toe/10/1
Which says its Red into Green, that looks like it matches with the picture you posted, because if you looked at that from the top the red side would be on the right, so it makes sense that it's the first effect. What it doesn't say is which effect is switched, so we don't know if it's Red or Green on it's own with the other being kicked in by the stomp.
It also sounds like the parallel mode isn't really parallel, it just selects between either Red or Green.
