Looper & fx loop pedal
Started by Krallum, August 25, 2010, 12:27:11 AM
Krallum
I have a laney vh100r and i love the fx loop options but it lacks a switch to turn off the fx loops. I'm planning on building a 3 looper (maybe 4 if i get a second amp) for each fx loop and one in front (this also will cut down on the shit i have to plug in everytime i set up, just run 3 chords and leave my pedal board alone). My question is:
If i do this with 3dpt switches how do i wire up leds?
I'm assuming i just use a standard 3dpt diagram like from the ggg site (except routing the circuit input/output to other jacks), but if i have all of this crap connected inside the same device and all grounded through the enclosure, will i have grounding issues? I'm not really familiar with how fx loops work internally in amps with multiple channels.
TimWaldvogel
YOU KNOW WHAT THEY SAY ABOUT LARGE PEDALBOARDS....
.... I BET YOU WISH YOUR PEDALBOARD WAS AS LARGE AS MINE
Krallum
i was actually looking at that earlier, but my question is kind of related to whether i can just stick 3 of these in the same box if its going to potentially be used for different amps, or if i will get a ground loop buzz like some ABY pedals have
TimWaldvogel
Idk about using it for different amps or how your intending on doing so. Buy I DO know throwing 3 in a box for creating loops in a pedal chain would work fine. Instead through take the output from the first switch and wire it as te input of the next switch until your ready to fix your chain
