homemade photo resist developer?
Started by fatfoohy, August 29, 2010, 08:32:30 PM
fatfoohy
I've found this linkhttp://hackedgadgets.com/2006/06/24/photo-etch-circuit-board-process/4/, but also read that sodium bicarbonate doesnt work for a developer...... so can any confirm whether or not this works? also, does anyone else have any other homemade recipes for photoresist developer?
having leftover parts is just proof that you made it better!!!!
Nasse
I have used drain cleaner that is made of sodium hydroxide, but you have to try and error the recipe, how much water is added
danielzink
That's for positive resist boards not the regular negative resist boards you get at Mouser etc..
I use a pool chemical you can get at walmart for my positive resist develops.
Dan
fatfoohy
Im going to be using these positive boards https://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_616260_-1 @danielzink- what is the pool chemical that you use?
fatfoohy
hmmm....i found some alkalinity increaser, its chemical make up is sodium hydrogen carbonate, is this what your's is? if not what is its makeup?
fatfoohy
