Trotsky Drive gain pot doesn't work
Started by FinchFex, September 05, 2010, 06:54:31 AM
FinchFex
I've built a (modified) Electra Distortion and implemented the gain pot as seen in the trotsky drive:
Pin 3 is connected to the 3.3k  resistor and pin 1 & 2 are wired together, right? If I wire it up like that I don't get any sound. If I don't jumper pin 1 & 2 together but connect pin 1 to ground instead I do have sound AND can control the bias of the resistor, but it doesn't control the gain in a linear fashion like you'd expect from a gain control.
Any suggestions where I went wrong?
Help much appreciated!
Hides-His-Eyes
try replacing the whole pot with a 50k resistor to check it's not a dodgy pot.
rico_wonderland
hai.... finch.... u must see the layout clearly.... see the layout wiring all component and pots, DC jack... all!!!
in the gain pot, leg1 in single way to 3.3k resistor.. and leg 2 nand 3 in same..... look in the pots pic there..... u can see the number of leg....
so not leg 3 in single way, and leg 1 and 2 in the same... not like my pic...
try to swap it....
Quote from: rico_wonderland on September 05, 2010, 08:39:25 AM
try to swap it....
wtf?...... ???
rico_wonderland
i'm just try to sugest... because, in the pdf project, i see wahat u see.... but in layout wiring board, different way... not like the schematic above...
Govmnt_Lacky
I think he is trying to say that you need to wire Lug 1 to the 3.3K instead of Lug 3 and follow from there.
