Is it ok to use 1/2 watt resistors in pedals?
Started by dmc777, October 01, 2010, 07:10:41 PM
dmc777
I've got some 1/2 vintage mojo resistors with .1-.2% tolerance and was wondering if it'd be ok to use them in a Colorsound Powerboost I'm building. I wanted to add some vintage parts and already have them but I know 1/4 watt is standard. Will 1/2 watt be ok?
Labaris
Yeah, they will work fine. It should be just a matter of room in your board, just like davent said ;)
But I have a question about this: ¿is that power rating a max. capacityor it's another thing?
A long way is the sum of small steps.
dmc777
Quote from: Labaris on October 01, 2010, 07:26:05 PM
You got me on the power rating. That's why I asked. I'm pretty sure they'll fit I just wanted to make sure they weren't to powerful or whatever.
frank_p
Resistors are passive, they don't give power, they dissipate power. You must use a power rating that is over what the resistor will effectively dissipate.
Labaris
Quote from: frank_p on October 01, 2010, 10:08:24 PM
So, no doubts about it now. Same thing with speakers, for example. They don't "give" N watts, they can "tolerate/handle" N watts fed into them by another (active) device.
These watts are electric BTW.
So man, don't worry about your resistors  ;D
GibsonGM
Larger tolerance resistors are quieter, so it's actually 'better' from an audio standpoint.
However, if they are "vintage", they are probably carbon comp, so they are inherently noisy just from what they're made of!  But they certainly won't hurt anything...
