IC Buffer Input jack problem
Started by sixstring531, October 05, 2010, 09:50:05 AM
sixstring531
First post here - hello everyone. This should be an easy answer, though at the moment I don't know it.
Built the GGG IC Buffer last night - works wells, looks great (like a gold brick) with a nice green LED. The problem I have encountered is that it will only pass the signal with the input cable pulled halfway out - ie, no signal when pushed all the way forward, great signal when pull halfway out. I can't have pictures until later, but it has to be a misplaced wire somewhere on the jack me thinks.
Here is a link to what i used.
http://generalguitargadgets.com/pdf/ggg_icbuf_lo.pdf?phpMyAdmin=78482479fd7e7fc3768044a841b3e85a
Just from looking at it again and looking at another photo (with location and names pointing to the appropriate places) I think I mis-wired the input jack. I think I made the TIP the sleeve and the sleeve the ring -- sound about right?
anchovie
sixstring531
