Digitech Whammy Pedal Question
Started by soupbone, October 17, 2010, 05:54:32 AM
soupbone
I keep going through these cheap adapters that are made for the Whammy Pedal.I try not to bend the wire going to the power source,but they keep shorting out!! :icon_evil:I've went through 2 in the last 6 months!!I can't use my voodoo labs pedal with it,but I was wondering if the "One Spot" adapters will work for it?
loki
hmmm the whammy uses 9v AC power... the power supplies you're using are probably 9vDC
soupbone
Is there an adapter,or a power supply,That i can build that you reccomend?
