Jack, 1/4 in. Neutrik #NYS212
Started by clamup1, October 22, 2010, 04:28:27 PM
clamup1
hey whats the layout for these jacks
3   2   1 <hole for jack
tip  ^
     sleeve
          ring
jasperoosthoek
No idea. If you don't know how to connect to a plug or a socket just hook it up to a cable or a known socket and measure with a multimeter. :)
[DIYStompbox user name]@hotmail.com
.Mike
Two easy ways to be sure with a jack of this style:
1. Plug in a cable. Use your multimeter to see what connects where.
2. Plug in a cable. Physically look as you insert the cable, and note what connects where.
Mike
If you're not doing it for yourself, it's not DIY. ;)
My effects site: Just one more build... | My website: America's Debate.
clamup1
this is what they look like if you need to know
http://www.smallbearelec.com/Detail.bok?no=771
i put a 1/4 inch in it and it looks like it Tip, sleeve, sleeve
Ronsonic
Call me on this if it seems harsh, but you can actually hold it in your hand, insert a plug and SEE what is connected to what.
The nomenclature for the parts of a jack are another thing. Starting at the pointy end, Tip, Ring and Sleeve.  Usually in pedals we use the Ring contact on the jack to connect the negative side of the battery to ground when a standard Tip Sleeve plug is inserted.
http://ronbalesfx.blogspot.com
My Blog of FX, Gear and Amp Services and DIY Info
Ice-9
You could try looking at this link , all the info you need is here. You are correct but remeber there are 6 connections as these are switched jacks.
http://www.neutrik.com/content/products/detail.aspx?id=210_1039603986&catId=CatMSDE_audio
www.stanleyfx.co.uk
Ice-9
sorry i didnt check but it looks like you have ring and sleeve mixed up, this similar jack has then named on the drawing pdf
http://www.neutrik.com/fl/en/audio/210_217181/NMJ6HCD2_detail.aspx
www.stanleyfx.co.uk
