Changing the pitch
Started by ment4lbre4kdown, November 04, 2010, 09:11:56 PM
ment4lbre4kdown
Having played around with alot of circuit bending on toys and stuff, I just had a thought. Shouldn't it be really easy to build a pitch shift pedal? Anyone got any ideas?
/Oscar
nick d
                       Possible - yes .  Easy - not really . Search Rocktave , E&MM Harmony Generator , to name but two .
                        Or buy a Digitech Whammy .
brett
Hi
Balanced and ring modulators do this.  Aliasers do something similar.  the search function is your friend.
Octaves modulate the signal with itself.
cheers
Brett Robinson
Taylor
No.
Pitch shifting is among the hardest effects to do. The reason it's easy with circuit bent stuff is that you are working with either a synthesized note, where changing voltage or resistance equals pitch change, or a pre-recorded note where you just have to speed it up or slow it down to get pitch change.
Working with a real-time audio signal is many orders of magnitude more complex. Some ways to do it:
Spin semiconductor FV1 - this is an integrated digital chip which already has pitch shift programs written for it. You just need to code your selected shift amount or range.
"Exploded" digital shifter - this is an idea I'm working on. Take a quadrature oscillator, turn it into sawtooth waves and use these to modulate delay time of 2 PT2399 delay chips. Use triangles derived from the original quadrature oscillator to crossfade between the outputs of the 2 delay chips. Use an OTA to control amplitude of sawtooth waves - this is your shift amount control, which can be a treadle ala the Whammy.
HT8950 - this chip is very ugly, lo-fi, and limited in shift amounts, but easy. Google "hazelwanter pitch shifter".
~arph
I tried modulating a pt2399 with a sawtooth once. The problem was with the sawtooth itself. If the falling edge isn't instantaneous the whole pitch shifting doesn't work. I guess by crossfading between two pt2399's you can avoid the falling edge. Is that what you intend with the crossfading?
Sounds like a tricky circuit, but doable.
Taylor's absolutely correct.
If you want to consider full-wave rectification, or frequency-dividers as "pitch-shifting", then I suppose that is a qualified 'yes'.  But the sort of continuous pitch-shifting that one might do with keyboards that generate an electronic signal via digital or analog oscillators IS bloody hard to do.
As always, I refer people to the review of the old A/DA analog harmonizer in Device, circa 1979.  That'll give you an idea of how"easy" it is to do in analog form: http://hammer.ampage.org/files/Device1-4.PDF
