One more for the masters to double check for me
Started by ode2no1, November 29, 2010, 12:35:52 AM
ode2no1
Haha ok so i don't want to bug everyone every time i make a layout, but i'm excited since i just started using the layout creator. does this look ok? i'm a little unsure of R4 for some reason. i also left a decent amount of space around the transistors because sometimes germanium fuzz layouts don't account for bigger models like 2N404's.
blueduck577
Right off the bat, it looks like you are missing a trace cut somewhere in the region of E8.  The base of Q1 is directly connected to the emitter of Q2.
ode2no1
ok the base emitter thing is what i was unsure of cause i knew i had to get R4 in there. i didn't realize that all i had to do was add a trace cut so thanks for pointing that out. the 1K is the gain pot so it's off board. does it look ok now?
