Please help me out - debugging my Ruby Bassman amp
Started by Rutger, May 09, 2010, 04:13:51 AM
Rutger
#20
I just make this my "Help me out!" - topic to prevent this forum from overloading it with topics.  :icon_mrgreen:
Last week I blew up my Ruby amp with a reversed 12V adapter pin. It's one of those adapters with different pin-sizes, and I placed it the wrong way so the center became plus instead of minus...  :icon_rolleyes:
Anyway, the 100uF cap was blown out and I replaced it. I also replaced the JFET allthough it seemed okay. Checked everything else but didn't find anything broken.
But I don't have any signal yet. I measured the voltages at the pinout of the LM386, everything is fine accept for pint 5 (output). There is a signal but it's only 0,2V instead of 5V.
Does this mean the LM386 is broken or is it something else?
MarcoMike
Only those who attempt the absurd will achieve the impossible.
Rutger
I know.. it's obvious and it looks like the Nr.1 Dumbass Question 2010 (maybe it is).
But i tested it with another LM386 I had lying around, with the same results. But that one is probably dead as well.
Rutger
#23
Okay.... plugged in a new LM386 and measured the right voltages. There is a signal now, but it's heavily distorted and it only comes through when I play hard. PLus there are noises when I turn the knobs.
I was thinking, because I reversed the voltage, could it be that the other elco of 200uF is damaged as well? Can I measure it somehow with a simple multimeter?
Or would it be something else?
Sorry for all the dummy questions, but I'm learning a lot from this.
