Flatline BUILD REPORT!!
Started by askwho69, December 04, 2010, 06:04:20 AM
askwho69
Helllo DIYers i build the Flatline and using the layout of Mark Hammer and in some topics about the capacitor to be use . . .C4=100uf, C2= 47uf, c5 100uf, LED(red), LDR, diode is 1N314 (i bought it in local electronic store its not the original germanium like everyone has)  about the sound it produce, its good but not the one i expected, its sound so clean to me meaning not compress like CS3? maybe because its a sustainer not a compressor" are they both he same? or not?" in sustain not so long sustain, i tried to use it as booster but i didnt like it CS3 is better.
My question is:
1.) how do you use your flatline? and how does it sound to you? any one has a clip on this?
2.) how was the LED and LDR sounds compare to VLTC and others?
3.) about the diode is this diode good? did someone tried this 1n314? "not the 1N314a"
thanks and more power to all!
A2
"To live is to die"
fatfoohy
I use my flatline for bass, and i put it right after my distortion, and leave it always on.  It doesnt effect my signal at all because all it does alter the gain of the op amp, so it's just my original sound, just more even.  the led+ldr combo is going to sound the same as a vactrol, but the brightness of the led, and the resistance of the led in either option will effect how much compression there is.  im not sure about your diode, but i dont think it's too choosey, i didnt use a 1n314a in mine, just a germ. part.  hope this helps!
having leftover parts is just proof that you made it better!!!!
askwho69
ohh thanks alot for the replyit really help... by the way what did you use? led and ldr? what led did you use?
thanks again
A2
"To live is to die"
fatfoohy
askwho69
"To live is to die"
Barcode80
For a cheaper alternative, I use these. The price is right, and the performance is great, especially in this application:
http://www.goldmine-elec-products.com/prodinfo.asp?number=G15396
fatfoohy
oooh nice link, it's worth it though for the consistency that it gives
Earthscum
Quote from: Barcode80 on December 05, 2010, 08:39:24 PM
Just make sure you don't order 10, or else they just grab you one of the "untested mix bags"... I got 1 matched pair at about 1.5M, 3 over 1M, 1 around 200k, 1 that was 10k, and 3 that were dead.  :icon_cry:
askwho69
Ohhh this is nice! i'lltry this one! :) so the conclusion is LED and LDR is not good enough for this comp :) thanks a lot for the replies!
"To live is to die"
fatfoohy
i wouldnt say that a led and ldr arent good, it's just that if you can, a photocoupler is easier and more reliable
askwho69
oohh ok thanks so much on this. it really helps i'll try this soon
"To live is to die"
