nedd help with how to identify potentiometer markings
Started by soupbone, December 15, 2010, 04:41:47 AM
soupbone
I need some help with how to identify pot markings.I know 100kA would be an audio taper,but i some more info on like reverse loger,logoryhthmic,and any others.Any help would be greatly appreciated! :icon_biggrin:
soupbone
blooze_man
logarithmic is the same as audio. B is used for linear and C for reverse audio.
Big Muff, Trotsky Drive, Little Angel, Valvecaster, Whisker Biscuit, Smash Drive, Green Ringer, Fuzz Face, Rangemaster, LPB1, Bazz Fuss/Buzz Box, Radioshack Fuzz, Blue Box, Fuzzrite, Tonepad Wah, EH Pulsar, NPN Tonebender, Torn's Peaker...
soupbone
jasperoosthoek
Keep in mind that in Europe A and B are reversed ::). So log/audio pots in Philips radios are B.
As blooze_man said, audio means log, reverse audio is C so reverse log is C ;D.
[DIYStompbox user name]@hotmail.com
teemuk
The letter codes vary continent to continent and each manufacturer also has their own take on them. On top of that, there are also other kinds of tapers than plain linear, logarithmic, and (sometimes) reverse log. The logarithmic tapers can appear in different varying functions and then there's S-curves and alike. Manufacturers sometimes use overlapping coding systems to cover all that. In other words, you can't trust that there's a universal and standard coding system. The one that exists now has a lot of discrepancies.
If you know the brand you can check the mfg's datasheets and application notes to see what kind of letter coding they use, if you don't, then your best bet is simply to measure the potentiometers.
cloudscapes
{DIY blog}
{www.dronecloud.org}
jasperoosthoek
soupbone
Quote from: jasperoosthoek on December 15, 2010, 07:10:52 AM
Cool.Thanks!
soupbone
Quote from: teemuk on December 15, 2010, 08:04:45 AM
Thanks to you as well!
