Dual Resistafier / Dr Boogie
Started by 0ron124, January 02, 2011, 07:33:04 PM
0ron124
Hi All!
I've been watching youtube vids and listening to clips and I think this is going to be the next pedal I build. I just have a few questions. How would I go about adding 2 separate gain knobs and a 3PDT switch to toggle between them kind of like two gain channels? Also what modification if any should be made to the pedal such as noise reduction or anything like that and if anyone knows which modifcations Jim at R3fx makes to the pedal.
Thanks in advance  :icon_biggrin:
flintstoned
Solder the gain wires from the board to the 3pdt's center lugs, then run one gain pot to the top row of the switch and run the second gain pot to the bottom row. If you're lucky and only needs two lugs ( like on a TS or dist+) then you can wire leds to the third pole.
I forgot what I was gonna say here.
