Bobtavia unwanted compression problem
Started by Mick Bailey, January 03, 2011, 03:24:27 PM
Mick Bailey
Just been playing around with a Bobtavia and I'm getting a nice distinctive octave using Schotttky diodes and driving it with a Bazz Fuss (Red LED) in the same enclosure. Between the two is a simple variable LPF (47k pot and 22n cap). The main problem is that the first note is loud and clear and then the signal immediately compresses and reduces in attack/volume. It takes about 2 seconds to recover after playing a passage. The attack is very much like a compressor on a hard setting. There is a good deal of promise if the compression could be removed and I'm happy with the overall sound. The problem worsens if I boost the 386 (switchable 10uf cap + 510R series resistor from pin 1 to 8).
Tried a couple of 386 ICs - LM386N-1 and a JRC386 - both with the same result.
The Bobtavia also compresses when isolated and driven externally from an external distortion pedal such as a Blue Clipper or May Queen.
Any ideas?
I think you are just over-driving it. There's ample gain in the LM386. More gain in front is over-over-kill.
Turn down the input, turn up the output.
DougH
Reverse the order. If you want more drive out of the bobtavia, use it to drive the fuzz box instead.
Mick Bailey
Spent a couple of hours investigating and putting the fuzz after the Bobtavia. Still no luck and after some considerable experimentation discovered that I'd got the output cap (2.2uf non-polarised electrolytic) between the diodes and the level pot, thus denying the path to ground for the diode bias and inducing the problem described.
Interestingly, I'd replaced the Schottky's with a couple of 'mystery' diodes (2-lead TO92 package - every one out of the pack has a different number but they all have .5v drop) and the result is now even better - easily the best octave pedal I've come across or heard.
The configuration is now Bazz Fuss (MPSA13 + red LED)/100k level/LPF/Bobtavia/47k output level. Needed a 100uf bypass cap on the 9v feed, a 4n7 cap from pin 3 to ground on the 386, and a 850pf cap across the Bazz Fuss input to prevent oscillation - seems to be a problem with running the two off the same supply.
I've socketed the Bazz Fuss diode and transistor for future experiments. Also has a boost switch and an octave on/off switch. Totally wonderful - cleans up ok and has tremendous range of sounds. Will still compress at higher gain, but the levels now need to be distinctly non-musical for this to be a real problem.
Can't recommend this configuration highly enough.....
