tremulus symmetry switch
Started by 1878, January 30, 2011, 12:49:20 PM
Hello Everyone
I once asked about adding the the symmetry pot to the Tremulus Lune without having the fine pot. This is what was decided upon...
If I wanted the symmetry switch rather than the pot, would I do this ??
Thanks in advance.
  Put a resistor across the switch of the potwafer value and have:
  The exact same thing the pot gets when the pot is:
  All the way CW [10] or atw ccw
  • , connects the wiper to one outside lug with the potwafer resistance to the other [and vice versa when switched.
      What this subcircuit connects to might not even care about seeing the potwafer resistance, only whether it sees the L or R diode.
1878
No probs.
I've just seen the schem at Fuzz Central, and it looks like you don't need the resistor.
Thanks...
