Line Level Splitter
Started by simon111, February 24, 2011, 05:29:40 AM
simon111
I need to build a mono line level splitter for my current band for stage use so we can be in complete control of our sound on stage.
Everything we do is at line level. I.e. Mixer outputs, Laptop outputs etc and also in Mono.
For simplifciation what I need is:
mono input going to three mono outputs. (all at line level)
I have checked out RGs hum free splitter and would like to ask if this would work? As  this is for guitar level and not line level I guess it won't. What modifcations would I require to get it to work?
Any help would be much appreciated.
Simon.
Gurner
If your signal is already at line level....then it's being sourced from a low impedance output somewhere  - therefore IMHO there's nothing to stop you splitting the signals with Y cables. By adding in an active circuit, you're just adding in more things to go wrong, extra noise blah blah.
simon111
That's cool. So I definitely wouldn't need something like an opamp splitter?
Quote from: simon111 on February 24, 2011, 11:17:21 AM
Definitely?
I don't think it's definite.
A gurner said, if it's already line level, it's from a low enough impedance source to not need further buffering. Probably.
If there was not an issue with hum, you'd be fine with a Y cable. Try it. If it hums, you will need some kind of ground splitting/isolation to get rid of the hum. But chances are better with a line level source than with guitar level.
