Boost with Loop al in one help?
Started by DonB, May 30, 2011, 04:45:07 PM
DonB
I want to build a Boost pedal (done) and combine the below loop pedal in one. So when the boost is active the loop is also active.
I need help with how to wire them up so it works from the one 3dpt switch with an led
Loop bassed on this vero
Enclosure design (to help understand what im after)
DonB
Can it be done or will i need to put another toggle for loop on/off then wire that to the 3dpt?
Connect Send to the input of your booster, connect the output of the booster to the send jack.
Here's a version of the layout with the LED added.
DonB
Had an idea but dont know if it will work. Can both boards be run is series to achive what im after?Would help cut down on wire clutter.
DonB
Had another idea...Put the boost IN the loop. Its the easiest idea to have them both work properly. But is the LPB1 boost ok to go in the amps effects loop?
