Rockman Distortion Generator.
Started by omarvolta, March 14, 2011, 07:22:20 PM
omarvolta
I just opened one up. There's a CL099 6-DIP chip in there that I can't find any information of. What is it?
6-pin devices are most often solid-state opto-isolators, in my experience.
omarvolta
I had a hunch it was going to be something like that since it is in the clipping part of the distortion circuit. I just couldn't find any information on this particular part number. Would the pinout on these 6-pin units follow a standard like op amps? What would be a good way to test it by itself?
wavley
I have always regretted selling my distortion generator, you used to be able to buy them in any pawn shop for $30 or $40, now you never see them.
Bone is in the fingers.
EccoHollow Art & Sound
eccohollow.bandcamp.com
Is there a patent number somewhere on the box?  That might help in narrowing down what it is, since many of Tom Scholz's patents come with schematic schematics (i.e., mildly articulated block diagrams, but not all component values or identies).
omarvolta
Thanks for your help Mark!
Back plate:
Nov - 8 1989
Serial No. DG11274
Pat. Pend. Model 100.
PCB:
EPC-1
REV 4
Distortion
Generator
16024
Nah.  That won't work, unfortunately.  Ton Barmentloo is a whiz with patent search engines, and, as novice, I'm resigned to putting in a patent number.  The number would likely have to be bigger than 4,000,000, and nothing you've shown conforms to it.  Anything on the board itself?
jaysg
Quote from: wavley on March 15, 2011, 09:26:44 AM
I have one somewhere.   How did you use it?   I found that the slider setting for a flat amp didn't deliver at all.  It seemed like it was meant to run into a gutar amp.
DSV
Should be a dual optocoupler (or whatever you call an LED+photoresistor) for the autoclean circuit. In my Sustainor there is a CLM50, in my DG the DIP package is replaced by 2 optocouplers, like in this photo:
http://rockman.fr/Products/DG91_Opto.jpg
Reference
http://rockman.fr/Products/Electronics.htm
