Hand drawn PCB manufacture
Started by trjones1, March 27, 2011, 02:34:02 PM
Look here:
http://www.4pcb.com/free-pcb-layout-software/
Haven't used it, but they say they give you Gerber files after your first order, instead of trying to hook you forever to them. Apparently they are only trying to trap you into a first order.
Gerber files are the industry standard. Gerber lets you order from any supply house. Want freedom? Get Gerber.
Perhaps the best option you have is to convince someone who can do layouts on gerber-producing software to do a retrace/relay of your hand layout. I have done this (no, sorry, can't do this one, not enough time) and it's trivially easy to reproduce an existing layout from a picture by entering it into a layout system. Couple hours max for simple hand drawn designs. Perhaps the liberal application of some foaming mental lubricant to a new friend who does layouts would work.  :icon_biggrin:
Steve Mavronis
Consider the ExpressPCB $51 Miniboard option. You can fit a couple same or different PCB layouts within a 3.8"x2.5" space and cut them out yourself later. You don't have to use more than one bottom layer for your design or use the top layer as a psuedo silkscreen in tin plated copper:
> 2 or 4 layer boards
> Tin/lead plating
> Board size must be 3.8 x 2.5 inches
> Fast manufacturing
> $51 for three 2-layer boards, $98 for three 4-layer boards
But I just use their software and haven't used their board making service. I print my single sided layouts to to PDF and get my own made by a family member, electroplated tinned and all.
Guitar > Neo-Classic 741 Overdrive > Boss NS2 Noise Suppressor > DOD BiFET Boost 410 > VHT Special 6 Ultra Combo Amp Input > Amp Send > MXR Carbon Copy Analog Delay > Boss RC3 Loop Station > Amp Return
