Optocouplers lots of them. ideas for use?
Started by wormfooduk, March 30, 2011, 10:21:52 AM
wormfooduk
Hi, ive just been given a bag full of tubes or these
http://www.farnell.com/datasheets/630968.pdf
Never used one before am i right in saying its like a led and ldr in one package?
What can i use them for i dont think ive ever seen a design with them in?
wormfooduk
Thanks for the guide should help alot. But has anyone used one in a Tremelo or comp?
cab42
Search for Flatline compressor. I really like mine.
Regards
Carsten
"Rick, your work is almost disgusting, it's so beautiful.  Meaning: it's so darned pretty that when I look at my own stuff, it makes me want to puke my guts out."
Ripthorn
merlinb
Quote from: wormfooduk on March 30, 2011, 10:34:33 AM
Those optocouplers are designed to be basically on or off, so they're not ideally suited for analog work. With a few opamps you could build a bypass/looper box, with the phototransistors acting as switching elements.
Another possibility is to switch them on/off at high frequency (above audio), at which point you can treat the transistor as 'a bit like a variable resistor'. Google "pulse width modulated phaser" or something; a few have been built.
Hides-His-Eyes
Quote from: cab42 on March 30, 2011, 10:59:45 AM
Regards
Carsten
these are digital optocouplers, not analogue ones.
pjwhite
These are not strictly digital optocouplers.  If you read the data sheet (and refer to Fig. 4 - Output Characteristics), you will see that you can put a small current in and get a small current out, put a larger current in and get a larger current out.  The CTR (current transfer ratio) is about 20%, so, for example if you were to put in 20 mA, you would get 100uA out.  The transfer is not completely linear, but it certainly may be useful in some effects pedal designs.
Not to be picky, but if the current transfer ratio is 20% and you put 20 mA in, wouldn't you get 4 mA out?
20% = 0.2
0.2 x 20 = 4
pjwhite
Yeah, you're right.  I didn't check my math.  I was going from the graph, but didn't really spend time analyzing it.  :icon_redface:
Hides-His-Eyes
So using a 150R series resistor, a wide-sweep LFO at close to the 9V rails would give you ~1-10mA current transfer; where does our input signal come into that? If we put our signal, biased, on the base, 9V on the collector and the photons limit the current output to give us our tremolo?
Can we ignore the base and use the C-E junction as a current limiter = resistor-like thing? PT2399 modulator?
The base-collector, and base-emitter, path of any bipolar transistor is essentially a diode.  Has anyone ever tried using an LED/photo-transistor package like this as a back-to-back diode pair for asymmetrical clipping?
In this case, you'd essentially tie pins 1 & 5, and 2 & 6 together for a clipping pair.
