Easyvibe Power option question
Started by krhnyc, February 18, 2008, 01:30:39 PM
krhnyc
Hi, I built an Easyvibe using the GEOFEX layout. 1st attempt was a failure, but lo and behold... I simply reversed the orientation of the LED's and, eureka! Sounds great BTW. If anyone wants an image of my revised layout (minor changes, incl. square pads for LED anode/cathode orientation and some tight traces cleaned up)... let me know. I redrew it in AutoCAD.
Here's my question, I wired in a power supply jack but when using the vibe with a power supply (boss psa) the effect sounds totally different. Uneven, no depth or swing. I was a little frightened, so I disconnected the power so to not fry something. It actually took a minute or so for the thing to recover and sound right again. I used it for a gig last weekend... sounded great.
Anybody know what would cause this behaviour. I have seen a mod on here involving a 100K resistor in series with with the jack, but it seems that that was there to eliminate ticking (which isn't a problem for me) also, it seems this mod would also put the 100K resistor on the battery.
Any suggestions?
Thanks.
'61 Strat, '56 Tele, other Strats and Teles, 335, tube amps, '68 Vox Wah, '76 Phase 90, '82 CE-2, '83 CE-2, '83 CE-3, Gray Box SCH-1, '89 DC-2, '80's DOD 280 & FX-80, '80's Vesta Fire Chorus, 18V Cool Cat, Home Built Green Ringer & EasyVibe, '92 SD-2, etc
EDLK
I would am in the middle of and easy vibe build
The polarity and orientation of the LED's would be a huge help as I have read some conflicting information
Thanks Ed
