Forumvibe ..Stupid question
Started by boogietube, April 16, 2011, 12:03:26 PM
boogietube
How do you wire bypass switching and led indication...It's not in the documentation.....
Sean
Pedals Built- Morley ABC Box, Fultone A/B Box, DIY Stompboxes True Bypass box, GGG Drop in Wah, AMZ Mosfet Boost, ROG Flipster, ROG Tonemender, Tonepad Big Muff Pi.
On the bench:  Rebote 2.5,  Dr Boogie, TS808
boogietube
Switching is obvious, but getting an led indicator in there is not,please help
jdub
Are you using true bypass?  If so, couldn't you use the standard 3PDT arrangement with a suitably large resistor on the LED (to prevent the 15V from blowing it)?
A boy has never wept nor dashed a thousand kim
RedHouse
Quote from: boogietube on April 16, 2011, 12:03:26 PM
Sean
Sean, it's not in the doc because it's up to you how you do it. Use a 3PDT as was sugested, or a RG Millenium Bypass, or whatever you wanna do, it's not part of the project so be creative on your own.
