Any theremin project?
Started by sushyoshi, July 11, 2011, 03:50:03 PM
sushyoshi
Hi!
I am interested in building a theremin. I would like to know if anyone build one or have any project that would like to share?
FUZZZZzzzz
i've build a few in the past, but mostly with ldr instead of antennas.. if i were you i would def stick with antenna and a more ' serious' build.. you will eventually be disappointed with something that only makes anti-bat signals.
search for jaycar for example.. try to avoid older schematics.. they will have a lot of hard to find parts.. i had some info on a theremin.. will try to dig up some
this one for example.. already has a pcb you can easily populate
http://www.thereminworld.com/forum.asp?F=3&T=3873&cmd=p
artifus
#2
google's quite good  ;)
*edit* also: http://www.diystompboxes.com/smfforum/index.php?action=search2
*edit*edit* doh! pesky internet! be sure to enter the word 'theremin' into the search box on that second link - i borked it and have failed to fix it. can't comment from personal experience with antennae as i've only cobbled together a couple of optical noise makers but have read that others have had reasonable results with the cmos theremin which is a pretty simple minimal component design and may provide insight into probe wah style controllers. would love to build an all valve version one day...
FUZZZZzzzz
artifus
nick d
               There's one on Beavis Audio Research , uses an antena and 2 CMOS chips ( 4069 & 4046 )
                 Looks cheap and simple ( ! ? ) , worth a look .
Hides-His-Eyes
nothing generating a square wave is ever going to sound like an actual theremin.
consider using a 'probe' (vex style) control on one of those VCOs with a sine output? (never tried it, always wanted to)
  Theremax, at PIAA.
      High quality kit, dual UHF carrier oscillator design = third-note [noticable in 'audio band']...very cool, especially with echo, very hard for me to play a tune without warmups to create a 'virtual index' by playing a few octaves and fifths with closed eyes to create a visualize index...an imagined theremin-fretboard.
   Good stability, ~easy to build, nice features, volume and pitch antenna circuits.
