filling a hole
Started by vendettav, May 04, 2011, 06:55:23 AM
vendettav
ok so i finally decided on making an alembic startoblaster and it sounds great. i changed the Resistor at the output to 240k which sounds a bit fuller!
but! my enclosure has 2 holes for pots. i am thinking of putting a switch instead of the second pot. so here's the idea: A. to put a switch that goes between 100k and 240k (a fat-switch) and B. putting a Bazz Fuss so the switch will do a true bypass between the fuzz and the booster. what dya think?
check my music HERE
Shredtastic psycho metal!
joegagan
if you can fit it,  plan B sounds awesome. each could be turned on separately, right? stratoblast ahead pf the bazzfuss? cool.
vendettav
well unfortunately it won't be independent: either the booster either the fuzz. but I am thinking of selling this as well so i lean towards the bright/dark switch for the booster which will give it a more commercial feeling huh?
check my music HERE
